Car hops up front unless i rev up to over 3rpms at take off
Posted: June 6th, 2006, 7:50 pm
by mazdamx3sohc
when im at a stop and start going again i have to rev up to over 3 rpms otherwise the whole front end of the car vibrates. theres no broken mounts or anything, at least im pretty sure there isnt.
clutch
Posted: June 6th, 2006, 9:41 pm
by forcedairram
Sounds like your problems could be coming from an uneven clutch, pressure plate or flywheel. Does it make any squeeling sounds?
Posted: June 6th, 2006, 10:18 pm
by mazdamx3sohc
nope just feels like a fast wheel hop
yea
Posted: June 6th, 2006, 10:19 pm
by forcedairram
Exactly, clutch chatter is exactly what it sounds like to me, hard to diagnose without seeing it. But that would be my hypothesis.
Posted: June 6th, 2006, 10:38 pm
by mazdamx3sohc
no clue man
Posted: June 7th, 2006, 9:00 am
by happyclown
Mine is starting to do the same thing... its not consistant though, very aggrivating when it happens though.
Where on the peddle should the clutch start to enguage... as I let the peddle out the clutch doesnt start to grab till the peddle is almost all the way out, I don't remember it being this bad, and someone told me that when a clutch is starting to wear down it grabs later and later
Posted: June 7th, 2006, 9:22 am
by mazdamx3sohc
sounds understandable, i mean sometimes its hard to get it into first and reverse, sometimes i have to let off the clutch and push it in again to get it to shift.
Posted: June 7th, 2006, 8:18 pm
by Bumpysbro
i have this exact same problem, i have a stock clutch but im going to replace it next week. i cant go into gears unless i let out then in on the clutch a couple times. and my tranny oil is low so gotta change that.
Posted: June 7th, 2006, 9:59 pm
by mazdamx3sohc
how do i change that? what kind do i need and how much?
Posted: June 8th, 2006, 3:10 am
by MechaManZero
I have that problem too....
JK lol
Yeah but that sounds like the same problem I had with my nissan 240sx before. What I did was change the master and slave clutch cylinder and everything seemed fine. Than all of a sudden the problem came back up out of nowhere and got worse. I couldn't change gears without speed shifting. I pull my tranny out and find a couple springs popped out of my pressure plate and one from my clutch disk. Changed the clutch and neverhad a problem since. I was like WTF mate. Well hope that helps you guys out.
Posted: June 8th, 2006, 8:44 am
by mazdamx3sohc
thanks. hey whats with all this master and slave talk?
Posted: June 9th, 2006, 12:29 am
by Boris
When my master went on my old 4runner, the pedal would actually stick to the floor sometimes. So if this ever happens to you, it's prolly your master.
Posted: June 9th, 2006, 9:57 am
by mazdamx3sohc
weird. my clutch does grab when its almost all the way out.
