Does the wastegate vent exhaust fumes?
If so, where and can it be rerouted?
WasteGate Venting
- cjthor
Re: WasteGate Venting
The Wastegate is used to control exhaust gas pressure to make boost. It should be routed back into the exhaust roughly 12 inches down the exhaust downpipe. Some people run a seperate exhaust pipe for the wastegate.nolig2278 wrote:Does the wastegate vent exhaust fumes?
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
It vents fresh air, so into the interior of the car is best. I run mine thru the firewall grommet on the driver side.nolig2278 wrote:Does the wastegate vent exhaust fumes?
![2 Thumbs Up :2thumbsup:](./images/smilies/2thumbsup.gif)
![Image](http://i255.photobucket.com/albums/hh134/Mazstylez/sig75.jpg)
rotflol, better watch he doesnt beilieve you and kill himself.Rick Johnson wrote:It vents fresh air, so into the interior of the car is best. I run mine thru the firewall grommet on the driver side.nolig2278 wrote:Does the wastegate vent exhaust fumes?
Bochek
