ze compression
Posted: May 19th, 2006, 8:56 pm
by RizzeRocket
anyone know what a good ze's compression should be at?
Posted: May 19th, 2006, 9:42 pm
by JWMX3
i believe 215 is perfect, minimun compression on a de is 143 i assume its the same for a ze
Posted: May 20th, 2006, 9:42 am
by lakersfan1
Anything above 190 on a hot engine should be acceptable. In the 210's would be great.
Cold compression numbers won't tell you that much ..... it'll basically just tell you if it's completely fubar or not.
Posted: May 20th, 2006, 9:47 am
by mxmaz
Different compression testers will give you different numbers on the same engine. The numbers being consistant is the key.
Posted: May 20th, 2006, 3:58 pm
by jschrauwen
JWMX3 wrote:i believe 215 is perfect, minimun compression on a de is 143 i assume its the same for a ze
And i thought it was 210...thanks Joe.
