ze compression
RizzeRocket
ze compression
Post by RizzeRocket »
anyone know what a good ze's compression should be at?
JWMX3
Post by JWMX3 »
i believe 215 is perfect, minimun compression on a de is 143 i assume its the same for a ze
lakersfan1
Post by lakersfan1 »
Anything above 190 on a hot engine should be acceptable. In the 210's would be great.
Cold compression numbers won't tell you that much ..... it'll basically just tell you if it's completely fubar or not.
mxmaz
Post by mxmaz »
Different compression testers will give you different numbers on the same engine. The numbers being consistant is the key.
jschrauwen
Post by jschrauwen »
JWMX3 wrote:i believe 215 is perfect, minimun compression on a de is 143 i assume its the same for a ze
And i thought it was 210...thanks Joe.
