pulled up at home last night and car died... wont start again.3/4 tank fuel.
its turning over finr but not firing... my best quess is fuel pump but not a machenic so not 100% sure. Car was not over heating and was driving fine before hand. plz hlp as im not in the mood for a mechanic bill that is hundreds of dollers!!!!!!
Yea check for spark, pull a wire from the sparksplug and have someone hold it very near a bolt or some ground source in teh motor. Crank it over and see if a spark jumps the gap.
hey man i had the same problem and mine turned out to be that the fuel pump connection wassent plugged in properly and it is very likely to happen in you took out your back seat and put stuff there ........like people or book bags ......and way just check it out......its worth a try
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
