Cant seem to find the smaller ball joints...
- Custommx3
- Site Administrator
Im replacing the balljoints on my GS, but noone seems to have the size I need.
The shaft is too large to fit into the hub, 1-2mm larger than the one I replaced.
I went through every ball joint for every year for my car and they were all too large.
Anyone have pics of the 2 styles?
Also, those early 92 owners such as myself, where did you manage to pick up a set?
- PATDIESEL
I ended up changing the hubs to fit the ball joint. Not a easy choice, but I figured why fight it.
Did you look at Rockauto.com they have a good selection of ball joints.
- im2bad4ya
I picked mine up not too long ago from rockauto.com I didn't install them myself, but they are fine, no complaints.
-1992 MX-3 RS w/BP Swap Tropical Emerald Metallic "Lucky" 2005-2012 *REST IN PIECES*
Worklog: viewtopic.php?f=46&t=78176
-2003.5 MAZDASPEED Protege #882 Blazing Yellow Mica "Lemon Drop" 2012-2015 SOLD!
-2003 MAZDASPEED Protege #1186 Spicy Orange "Debbie" 2014-2015 SOLD!
-1980 Toyota Corolla Green 2014-present
-2002 Lexus IS 300 Solar Yellow 2015-present
hmm. Canadian Tire...never had an issue.
do you guys have any part numbers to share? i need to change the ball joints on my gs too.
there are several part numbers listed in the link below. can ball joints not interchanable between the different
http://www.autopartswarehouse.com/shop_ ... a/mx3.html
- 1992blazeredgs
- PATDIESEL
Sept 93' is supposed to be the mid-year change. However, be careful I've seen pre-Sept. 93' cars that were acutally post mid year change. My car is a Aug. 93' and if a pre change car.... Go figure. It must have depended on which factory your car came from, but I cannot imagine Mazda using more than one facotry to build the MX-3... <shrugs>
As for the part number it would be hard to reference a Mazda part number for a aftermarket part. I've tried that, and the manufacturer cannot tell which part theirs matches based on the Mazda part number. Usually they will tell you based on the year and if necessary, such as in the 93' split, the month your car was made which part you need.
- im2bad4ya
VIN #000001-227696=Smaller Ball Joints
VIN #227697 and up=Larger Ball Joints
According to many auto parts websites.
customescortgt
