air flow meter
jojo2k23
air flow meter
Post by jojo2k23 »
Can i rebuild my air flow meter?The thermosensor inside is burn.Where can i find this part at?With it burnt it gives a high idle of 1100 rpms at all times and for some reason gives a quick up and down at 2500 rpm on any gear.
CoSpringsMx-3
Re: air flow meter
Post by CoSpringsMx-3 »
What here is your mx-3? You have the black cylinder air flow meter. If so I have an extra one. Let me know.
David Coleman
Re: air flow meter
Post by David Coleman »
I sure don't think you can rebuild one. Mason Holmes has two V6 VAF's that he is willing to sell I believe. Email him at Masonholmes@hotmail.com . <P>------------------<BR><B><I>David Coleman</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><A HREF="http://www.highlandsun.com/hyc/sae920677/" TARGET=_blank><I>V6 engine info</I></A> | <A HREF="http://www.bradbury.cwc.net/probemx/index.htm" TARGET=_blank>KL FAQ</A> | <I><A HREF="http://www.brownsword.ca/Probe.html" TARGET=_blank>ECU reprogramming</A></I> | <A HREF="http://members.home.net/tekguy/" TARGET=_blank>K series Image cache</A> | <I><A HREF="http://archive.probetalk.com/cgi-bin/se ... tion=intro" TARGET=_blank>Probetalk Archive Search</A></I></B><BR><B>Support OPEC: Buy an SUV</B>
David Coleman
jojo2k23
Re: air flow meter
Post by jojo2k23 »
my car i a 1992 4cyc sohc.What readings(ohms) do u get at connectors E2 &THa.With the car cold.I get 1500-1540 ohms and it should be 2100-2200 ohms from the book.
