Next question... Is there an easy to find unit that will work?
Just a little confused. Your going to have 2 TB in engine bay - one with coolant lines bypassed and the other set aside with the ISC plugged in?????fowljesse wrote:I did it a long time ago, because I drive long distances across the desert, and it ran great. But now I'm going north. I was going to mount a second TB maybe where the battery was, and hook the sensor up to it. That way it works & I don't have to run hot water into my IM after the PITA of putting in the pheno spacers.
That's what I was thinking, because I don't have the TB pheno spacer, but now, I think I'll just make that spacer.Just a little confused. Your going to have 2 TB in engine bay - one with coolant lines bypassed and the other set aside with the ISC plugged in?????
I'd say that there may be a possibility that a missfunctioning ISC coukld contribute to a richer running condition. There is a very easy way to test the operational integrity of the ISC from the online manual. Since I don't have my manual handy with me at work, vague recollection tells me around page 102/103 in the V6 section. Pulling the 2 wire connector from the ISC and checking the resistance values fall within prescibed tolerances based on subjected outside temps that again is found within the online manual. Just gussing here but something in the range between 10.6ohms and 12.3 ohms I believe. Hope this helps.bluemx3 wrote:hgallegos915,
How do you know you have a bad AIC?. I also get very poor gas mileage and my idle when cold is very hi, but it does come down when it warms up. I ran a check for codes and come up with nothing, but I'm trying to figure out why my car gets poor gas mileage, maybe it tis the AIC. How do I check it? Other then the hi idle when cold, the car runs great.
jschrauwen wrote:Just a little confused. Your going to have 2 TB in engine bay - one with coolant lines bypassed and the other set aside with the ISC plugged in?????fowljesse wrote:I did it a long time ago, because I drive long distances across the desert, and it ran great. But now I'm going north. I was going to mount a second TB maybe where the battery was, and hook the sensor up to it. That way it works & I don't have to run hot water into my IM after the PITA of putting in the pheno spacers.
First it should encounter no side effects from running with the phenolic spacers w? coolant lines attached.
Second, ECU likes to haver that ISC valve info as part of the fuel richness calculations when setting idle and when driving. It's part of the ground zero set-up.
Third, If you want to know the actual difference, just uplug the 2 wire ISC Valve connector before your morning start. Your engine may or may not even achieve a reasonable idle, especially if it's the least bit cold outside. If it does attain an idle, than your basic idle set-up is incorrect to begin with so don't assume that everything is still OK.
Fourth, When it is started with the lines bypassed, engine will not go the prescribed high idle on cold starts as it's supposed to. This is an ECU generated process to richin the mixture which is easier on combustion when it comes to cold metal on metal part friction. Engine efficiency is based on running at an optimum temperature.
Fifth, the coolant lines will do exactly that - COOL the TB during excessive temps - and that's a good thing..
Sixth, why would one want to mess with something that works quite well, funtions to improve operation and performance since there's no performance or advantage to be gained by doing that mod. Mine works quite well with the phenolic spacer.
If it ain't broke - don't fix it!!
