Short Shifter
Short Shifter
i am thinking of installing a short shifter onto my stock mx3 1.6 liter sohc. the only thing i have done to it is put on a cold air intake and a glass pack muffler, my question is, would the short shifter hurt the stock cluct? you know since you will be slamming through the gears faster. thanks for help
- monty73741
The short shifter,
my second mod
remeber the short shifter just moves you shift point.
the shifter is just a lever , the higher the pivot point is the shorter the shift
jason
my second mod
jason
Jason Danaher
Please Help Support MX-3.com
- corbanbrook
go B&M
I'd recommend B&M for the job. I just did the swap about a week ago; it was pretty easy and the feel is outstanding. I'm not quite sure why, but I can now get the tires to chirp into second, where I couldn't before. Just my 2 cents
95' MX-3 RS, front and rear stabilizer bars, B&M short shifter, homemade ground kit, all power options just installed, passport 8500 X50 radar detector (+15HP, -8mpg, +20mi/hr top end on the highway)
Re: go B&M
Hey, I just installed my B&M shifter. Did you reuse the top O-ring and the retaining spring like the instructions said? I pushed the shifter into the rubber seating as far as I thought I should and there was no way I could reuse those parts. If I did shove that entire blue pivot housing in I don't think I'd ever be able to get it out if I ever had to. Is that housing supposed to serve in place of the O-rings and retaining spring? It's shifting but, I don't know if the feel is supposed to feel the way it does. Anyone else that has done this install?mx3dude wrote:I'd recommend B&M for the job. I just did the swap about a week ago; it was pretty easy and the feel is outstanding. I'm not quite sure why, but I can now get the tires to chirp into second, where I couldn't before. Just my 2 cents
Thanks.
Jay
o-rings and spring
You do not need the white o-rings that were on the original shifter. The housing replaces these. As for the retaining spring, I believe you are supposed to put it back in, but I just couldn't get that thing back in. The shifter sits so tight, I really don't think it's necessary. I've been driving around for a little while now and haven't noticed any play, vibration, or movement. Hope this helps.Hey, I just installed my B&M shifter. Did you reuse the top O-ring and the retaining spring like the instructions said? I pushed the shifter into the rubber seating as far as I thought I should and there was no way I could reuse those parts. If I did shove that entire blue pivot housing in I don't think I'd ever be able to get it out if I ever had to. Is that housing supposed to serve in place of the O-rings and retaining spring? It's shifting but, I don't know if the feel is supposed to feel the way it does. Anyone else that has done this install?
Have Fun,
Chris
mazdamx3sohc
Re: o-rings and spring
Have Fun,
Chris
I don't have to "find" the gear I want anymore but, I was also under the assumption that getting a short shifter installed with the "ever so popular" SRD bushings would eliminate that "shifting feeling" eg: 2nd, click, 3rd, click, 4th... I hope that makes sense. Anyway, I was hoping that I wouldn't feel that shift between gears. Could it mean that I've tightened the bolts too tight or is that normal?
Yeah, I love this forum. I'm on here so much and I'm sure everyone's sick of all my questionsdtfbrad wrote:well this site is awsome i have found allmost every question i have on here u guys rock!!!
Jay
mazdamx3sohc
