Rad Fans
it would help to know you year make n model but fans are pretty tough on mazdas and rairly fail [ atleast in texas]
older models have a thermo switch near the t stat housing very common failure
later models the fan is controled by the ecm
ussually a bad relay or temp sensor / fan switch
JUDGE ME ALL YOU WANT
93 gs, klde swap, kl trans, strait 2.5'' ehaust, euro front bumper, cold air intake, hei ign ,50 shot &
9.60s n the 8th mile so far 8.50s sprayn now
150 shot
150 shot
- corbanbrook
jnic wrote:are the rad and fans the same on the 6cyl and 4 cyl???
no radiator and fans are diffrent v6 fans look slimer and have to speed motors
150 shot
150 shot
the stock v6 ones are hard to beat most aftermarket fans suk even high fow onescorbanbrook wrote:A little off topic, but are there any performance fan blades i can purchase that would out perform the stock ones?
stock ford fand are nice
over all salvage yard hunting would yeald some cheap very high flow fans
the only good reason to buy aftermarket high flow fans is for extra space like for a turbo or sumthin
150 shot
150 shot
There are two fans on the 93 and 94 MX3 4 cylinders; the one on left only comes on when the A/C is turned on. The right is the cooling fan. Mine did the same thing I just bypassed it and put a switch inside, kinda assway around but now I KNOW when the fan is on cause I control it myself...LOL...your issue is most probably the relay switch. Go to the tech pages here to find it and replace
