MPV fifth gear
slimmyslim1420
MPV fifth gear
Post by slimmyslim1420 »
I remember reading on someones post don't remember who but they said something about putting a MPV fifth gear in there mx tranny cause it was wider. Is this true. How much wider is it. Which MPV do you need to get it out of? And is it a direct swap?
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
lakersfan1
Post by lakersfan1 »
I didn't even know an MPV came with a stick shift.
slimmyslim1420
He may have been talking about an automatic if they even had a 5 speed tranny. But I don't know. I wish I could have found that post. I looked for about an hour.
Devlin
Post by Devlin »
why not go with an MX-6 tranny if u want a taller 5th?
