ATX to MTX swap. Deconstruction nearly complete.
So far parts removed:
Seats
Center Console & Atx Shifter, TCM and shift cable.
Battery & battery tray removed (will not be reinstalled)
Factory Airbox assembly removed (will not be reinstalled)
Axles & Halfshaft (was far easier to remove these than what I was led to believe)
Engine & ATX have been removed
Wiring harness was pulled with the engine and will be replaced.
Parts still to be removed:
Stock ATX Brake Pedal Assembly.
Note worthy observations:
The #6 spark plug wire was not seated into the distributor cap.. this was likely the reason the engine kept throwing a code 17 even after the previous owners replaced the O2 sensors.. nice that I wont need to dink with them. I have a couple of pics of this (was damn funny LOL) Here ya go:
There was a minor amount of oil in the #1 spark plug hole... enough reason to replace the valve cover gaskets before it gets really bad.
The studs in the exaust manifold collector flanges were an extreme PITA to get out and will need to be replaced with a better system to hold the flanges together. I WILL NOT use the same system again.. idiots.
Parts bought so far:
MTX swap kit - including trans, clutch, axles/halfshaft, wiring harness and mounts, etc..
Timing belt kit
Axle seals
Pilot bearing
Shifter Bushings
Parts still to come:
Millenia Alternator
Valve cover gaskets
Intake Manifold Gaskets
Exaust Manifold Gaskets
Exaust Manifold Flange donut gaskets (idiots)
NGK Plug Wires
NGK Spark Plugs
Distributor Cap & Rotor
CAI Kit (likely will design & build my own)
Battery and relocation kit to mount battery in spare tire well.
Possible side project under consideration:
I am seriously considering removing everything from the fender wells and firewal in the engine bay and sand blasting it all down to bare metal and then primering it and painting it before reinstalling everything. Will depend on timing and how soon my back will allow me to start working again.
Tunes67
