Straight neck in mx-3 how-to ?
hi everyone . Someone can tell me how to put a straight neck intake manifold in a mx-3 with details, i know someone of you and moca members made it. thank you.
Mnemonic
Dont forget after you swear in we sit 2 guards at your mx3 at all time to make sure no one pops the hood to find out exactly how it is done. These 2 wont protect your car in anyway from it being stollen or vandalized they are only there to make sure no one opens teh hoodmxmaz wrote:You'd have to pay moca for them to tell you how to do it. Then you'd have to sign a contract sworn to secrecy that you wont tell anybody else how it was done.
There are other memebers on here that have done it though, and i am sure they would be willing to spread their wisdom.
Besides guys its not hard to figure out if you looked at the problem the straight neck causes when installing there is only one possible explenation on how to solve this problem.
And for the record i opted not to go with the straight neck ZE
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
hgallegos915
you can go straight neck with any k series engines that have ROUND runners... good luck if its a ze straight neck. Use search... a coupe of us swapped. When done on a k8 its bolt on however you loose low end power bohoo or something like that.
-hec
The straight neck you are talking about is the one from the klde. Those are commonly known as "short necks". They have short straight necks but people refer to them as short necks, so as not to be confused with the ze straight neck. He is talking about a ze straight neck. As far as i know, no one has ever bolted a straight neck ze IM on to a k8, and if they did there would still be the same fitment issues.hgallegos915 wrote:you can go straight neck with any k series engines that have ROUND runners... good luck if its a ze straight neck. Use search... a coupe of us swapped. When done on a k8 its bolt on however you loose low end power bohoo or something like that.
- PATDIESEL
It took me about a week to figure it out and I've imporved the design each of the three times I've done it for MOCA members. All it takes is some tought and some ingenuity If you haven't got those skills you should sell your MX-3 anyway since that is a requirement if you want to really mod the car.
Eat my shorts if you don't like it.
- jschrauwen
PATDIESEL wrote: Eat my shorts if you don't like it.
Pat, perhaps a few close up pics by the brake MC of what he's up against to prove the point. Have you documented your specific procedure(s) for this in MOCA for him (or other members) to review when this question arises again?
This is the exact reason why you should let the community know how you do it. If you feel your way is safer then the way that others have been doing it, then why not let us know? Its not like you are the first one or the only one to ever do it, you just did it a little differently and safer according to you. So its not a matter of originality, its a matter of safety for your fellow mx-3 enthusiasts. So come on, give it up man.PATDIESEL wrote: It is not hard, but will be very dangerous if you don't think about and fix all the problems it can cause with the brake master cylinder.
- PATDIESEL
from my above post JohnI'm not giving my secret away
Sorry Bro, it is my mod. I'd tell you pretty much anything else, but this one is just for me and my close MX brethren.
Also, I know a few guys who did it the EXACT same way I did without me ever telling them anything.
It shouldn't be hard to figure out or to make safe. I'm just saying that if you try then pay special attention to the proximity of the TB to the master cylinder.
Also, other than to be different than others in a already small community would you want to go through the hassle? Then by that rationalle why would you do it if then you are not different b/c then you are like me...
I get this a few times a year.. I just want something that sets me apart. That is why I bought a MX-3 in the first place.
I don't have a crap load of money to make my car totally different, but this is one thing that makes my engine bay look completely different than any other.
Honestly, good luck if you try and I hope you are safe with it. If you'd like you can even send me pics of your finished product and I'll tell you if I think it is enough to keep te 200 HP motor from pushing back into the brake mechanics.
Mnemonic
Hey thats the reason i didnt do itPATDIESEL wrote:from my above post JohnI'm not giving my secret away
- jschrauwen
Would I be getting warm if I were to say that a different 60mm TB would have to be sourced. Since there would be ample room to the left of the TB, a TB with the ISC on the left would work and not be in close proximity to the thermostat housing and no where near the brake MC. To that left handed ISC TB, one might want to take the throttle linkage and virtually tumble it or turn it upside down so as to pull from the top and not the bottom which (now I'm really guessing here) I believe may negate the proximity issue again with the brake MC. Attach to the TB and immediate 90 degree coupler to run to the VAF. This set-up will also probably necessitate the need to relocate the battery to the hatch area.
Please tell me I'm getting warm or close?
pssssstt ....I won't tell.....
........dohhhh!!
please don't tell me that all you did was some shimming on the firewall for the brake MC and re-adjusted the interior linkage to compensate.
........dohhhh!!
- garfy1981
my straight long neck went straight in no problems...............
but then i am in the UK, so RHD = master cylinder on opposite side lol
no secret here then.
2.5 Ze straight neck, blitz intake, mazdaspeed engine mounts, fidenza flywheel, CM II Clutch, KL-36 ecu, Magnecor 8mm Leads, Battery Relocation. Hotshot headers, 2.5 mandrel bent stainless exhaust, hi-flow cat, Speed hut dials, custom coilover set up. Custom willwood big brake conversion.
mx34u2nv
i thought u still used the ze tb, and just die grinder to it....use little throttle wheel from k8...i had it in an email its here some where......
Full fx designs body kit, Apex lowering springs tokico struts, walbro fuelpump, klze, 17" sachhi wheels, b'm short throw shifter, ractive frount and rear tower bars, kl36 ecu. all for sale....pending
- JWMX3
Genious !!!garfy1981 wrote:my straight long neck went straight in no problems...............
so that was it... patdiesel had RHD mx3s imported for him and all his buddys..... that fraudulent bugger
