Seatbelt problems, inspection past due... HELP!
went to see Mazda today... been having problems with my driver side shoulder belt. i explained that part of the cable came out of the track, which is causing the unit to retract. i tried using the manual slot, itd catch, turn, then it refused to move. they took my name and information, then proceeded to tell me it was at least 40 bucks for the guy to look at it. needless to say i left.
ok... as explained above, ill try and explain in more detail. a few weeks ago my shoulder belt started acting up, ive had the recall done on this already... when the door closed and car was on, the seat belt retracted half way, and when it did, a portion of the cable spooled out from the door closed position of the belt. i managed to fix the protrouding cable, unplugged the motor to the seatbelt so i could work on the unit. after 20 mins i couldnt figure it out. i managed to get a enough of my trim and panels moved so i could easily see everything. now theres about a .5 inch section of cable that is sitting on top of the track near the bottom of the seat belt track. ive tried everything i could think of to pop it back in place. anyone got ideas? anyone done this?
*note i will not be doing the rx7 hatch conversion, id rather get a BP*
- mitmaks
can you post some pics how it actually looks like?
- Franko
Umm.. Im fairly certian that those seatbelts are covered for the life of the car.. I dont think they are allowed to charge you for a recall like that. Go back in there and explain that this is a recall situation and obviously it has not been fixed.
- jschrauwen
Someone actually posted a scanned copy withing the last few months I believe of that recall (or whatever it's called) that indicates the specifics/details surrounding the auto seatbelts. Try that.psyense82 wrote:well thats what i was thinkin Franko, but is the whole unit covered by the recall, or just part of the auto seat belts?
think so?
question...wat if my retractable belt isnt there anymore....for instance when i bought the car it didnt come ith one becuz the guy cut it off....think itll stll be covered?? its only on my driver side
Re: think so?
That sounds like a warranty-void situationletoplaya4 wrote:what if my retractable belt isnt there anymore....for instance when i bought the car it didnt come with one because the guy cut it off....think it'll still be covered?? its only on my driver side
- PATDIESEL
I don't think they will replace a missing seat belt for free. However, get one from a junk yard and put it in. If it doesn't work THEN go to Mazda and have it fixed or replaced.
