Miata Rotors?
reprobation
Miata Rotors?
Post by reprobation »
Hi, I have the chance to get a set of cross drilled rotors for a 89 to 93 miata, for about 25 bucks, i was wondering if they would fit! and i need to know ASAP!
thanks!
-Chris
mitmaks
Post by mitmaks »
fit what, mx3 gs, rs??? i wouldnt get cross drilled rotors myself they do not perform well
Shades
Post by Shades »
Bolt pattern would be the same... but might wanna check the thickness and diameter of the rotor... also as well as the width of the pad surface.
Hit up a rotor site like Brembo or someone and cross reference the part numbers for a Miata and a MX3... if they're not the same then most likely they're not the same.
"Do it ONCE, do it RIGHT!"
mitmaks
Post by mitmaks »
im pretty sure its different part at least miata compared to GS
reprobation
Yeah, I have an RS... do you think it would line up okay?
jaydog5678
Post by jaydog5678 »
Well yes they are a different part# and they are not 100% the same, however they will fit the Mx-3. 8)
There really is no big difference. The diameter is just a hair larger than an Mx-3 rotor. The rear rotors from a Miata will work on the rear of the Mx-3 as well.
PATDIESEL
Post by PATDIESEL »
I use them b/c they are alot cheaper than MX-3 rotors. All four work just fine.
PS, on the cross drilled and slotted, they are going to brake less (not by much though), but look cool. They also have a tendency to break so don't get them unless you get a high quality manufacturer like Brembo and make sure the cross drilled portion is chamfered (looks like a counter sink dimple on a drilled hole- if you know what that looks like).
