fuel smell outside the car
My 93 GS has a strong gas smell on left rear side. How to debug this and get it fixed?
Check your fuel pump for leaks. Check lines... even if its the rear CHECK engine lines... my car fried UGLY because of a needle size leak. Dont over look it. also the pipe that feeds the gas tank when refueling tends to rust.
-hec
- 93-Spec-Edn
how can u tell if theres such a small leak?hgallegos915 wrote:Check your fuel pump for leaks. Check lines... even if its the rear CHECK engine lines... my car fried UGLY because of a needle size leak. Dont over look it. also the pipe that feeds the gas tank when refueling tends to rust.
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
well it would smell from the front of the car..there are basically 2 main lines that come from the injectors. Just inspect..i think your problem may be a leak with the fuel pump itself or the pipe that i was talking about since its on the outside.
-hec
- MX3 GSR for dummies
9 times out of 10 it will be the return line. If your search results in nothing. Clean off all the lines and re-inspect later. Try to do this on a dry day so any fuel may be felt. Another trick, last resort, is to release your gas cap after driving and if the smell goes away after trying this for a week, you know it was a pressurized line rather than the return. Good luck and remember, whenever working on fuel issues, have a fire extinguisher on hand!!!
If at first you don't succeed....it never happened
94 mx3 GS w/ KLZE, KL31 ECU, clutchmaster stage 3, cross drilled rotors, Custom ram air intake, Custom exhaust, Toyo tires, 250LPH fuel pump, Modified Distributor, Upgraded Wiring etc, external HEI, Full Body Drift kit and freshly painted Grey. Interior neon accents and much more in progress
- Tunes67
Just curious.. when you remove your gas cap.. do you get the sound of vacuum being released? A sucking sound of sorts. If you dont.. try a different gas cap. If your gas cap isnt sealing properly fumes could be escaping around it. Just a thought. Cheers
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
- mitmaks
most likely gas cap leak, emissions places over here make you replace them after a while
