you envy my car..you know it... NOT
hgallegos915
ok YAY got headers installed runs ok needs some tunning... going home i hear a snap.. hmm then grinding..turns out my cv shaft snapped./..wtf and it snapped where then nut and shaft meet... so yet antoher problem for this piece of crap mazda.
-hec
- Aston Wards
- jschrauwen
I don't know Hector. You have to be one of the most unlucky MX owners I've ever heard. I don't think you've ever gone more than a week without some major fault or flaw. Engine fires, bent internals, mucked up engine swaps, snapped CV's. If it wasn't for bad luck, you wouldn't have any. Sometimes it's better to wipe the slate clean and start over .... sometimes.
hgallegos915
yup very bad luck with this car about the posts well i guess its good that people see that I have replaced EVERYTHING..lets see..engine , mounts, all 4 strutsa, strut munts, ENTIRE IGN system. brakes brake likes, ecu, passenger side cv shaft. hmm after i get this fixed i wonder what will go next or and i think one of my vris solenoids died so gotta get another one. This crap. I know ill end up selling it locally right after i paint it.
-hec
- slimmyslim1420
Just think though. By the time you get done everything on the car will be brand new. So who ever gets it shouldn't have to worry about working on it for a while. That is as long as they don't have the luck that you've had with it. I'm curious though if you plan to get another mx-3 or a Mazda at all for that matter? It seems you might be tired of them. But I know I love my car along with a lot of other mxers. If you do get something else you know you'll buy another mx-3 one day. There just to hard to resist.
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
snellgrove
lakersfan1
Seriously. Roll it off a cliff. Once you had that under hood fire, you should have cut your losses then. All sorts of gremlins happen after a fire .... though that can't even explain ALL the stuff you've had happen. Maybe it's cursed or something. Maybe some Cajun witchdoctor from New Orleans ..... you've got displaced Katrina victims in your town, right? That must be it. Go to the nearest rock quarry and put a brick on the gas pedal.
hgallegos915
we dont have quarries
its the desert ill post a cpi of what happened... hmm paitn and sell to some poor local soul. no warraty as is lol. Im looking into an american car something thatpoarts are not 100 dllrs a bang. Manual.
-hec
- MX3 GSR for dummies
I always believe in preventative maintanance. When I engine swapped, I put new drive shafts and replace suspension. But by the sounds of it, even your luck would prevail. I thought I had issues with my car. MAn I feal for ya! Good luck on the sale.
P.S. What rattles very loud and shakes very violently....Every American car out there now that your lookin for one.LOL
Take it easy on your next car o.k!!!
If at first you don't succeed....it never happened
94 mx3 GS w/ KLZE, KL31 ECU, clutchmaster stage 3, cross drilled rotors, Custom ram air intake, Custom exhaust, Toyo tires, 250LPH fuel pump, Modified Distributor, Upgraded Wiring etc, external HEI, Full Body Drift kit and freshly painted Grey. Interior neon accents and much more in progress
Juans_93_MX3
Wow, where did your car come from (what state)? Where was it orignally bought? A dealership? Auction? Private?hgallegos915 wrote:yup very bad luck with this car about the posts well i guess its good that people see that I have replaced EVERYTHING..lets see..engine , mounts, all 4 strutsa, strut munts, ENTIRE IGN system. brakes brake likes, ecu, passenger side cv shaft. hmm after i get this fixed i wonder what will go next or and i think one of my vris solenoids died so gotta get another one. This crap. I know ill end up selling it locally right after i paint it.
I know my car came from Florida and somehow made it to Utah where it auctioned
Its pretty wierd because I found this stuff on the Owners Manual where the original owner signed a Warranty pamphlet
The MX3 used to give me problems. It is running pretty fine right now except that I think the waterpump might give up on me soon. KLZE engine swap, here I come
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Mnemonic
Your in the desert? Well then you can pick up some black powder and pvc pipe and make your mx3 a really big fire works display for new years
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- PATDIESEL
I liked the guys who slapped a missle on their car and ran it down some rail-road tracks and into a plateu in the desert. You could do that, it seemed like it would be aweful fun
I hope you don't expect to have any luck with an American car... I've owned a few and you are right the parts are generally a little cheaper, but you have to remember that American manufacturers are very bad about creating parts for one car and thus the cost is great and the part is usually very crappy b/c it wasn't tested properly. Also expect to work on it more than your MX-3 since they break ALL the time. If you want a good properly running car with minimal headache buy a Protoge. They sold tons of them, Protoges share parts with tons of other cars thus cheaper parts. They last forever and a usually cheap.
You do have the worst luck I've seen on this board in the whole time I've been here.
hgallegos915
well corrected problem, 50 dllrs for a new cv joint with spindle. I fixed my vris solenoid, headers are installed..they may have a leak well the rear ones. Reset idle and disty timing. Connected iac (was disconnected) Went for a test drive and io have to say wow... there is a huge difference from before. I went driving harsh for around 30 mins to test the limits...ricer civics attempt to look cool buyt got embarrased on their own.. i missed this car..
-hec
