injectors
Posted: December 12th, 2005, 8:01 pm
by mx3stylez
hey everyone, i got a quick question i need help with. i am trying to figure out which injectors i should go with. i hears from a friend that i could use rx7 550 injectors and he can get a set of them for $300. this sounds like an awsome deal, but i'm not sure if they would work. any input on this or an alternative would be appreciated.
Re: injectors
Posted: December 12th, 2005, 9:35 pm
by Josh
mx3stylez wrote:hey everyone, i got a quick question i need help with. i am trying to figure out which injectors i should go with. i hears from a friend that i could use rx7 550 injectors and he can get a set of them for $300. this sounds like an awsome deal, but i'm not sure if they would work. any input on this or an alternative would be appreciated.
well first off what motor do you plan on using?? BP, B6, B6T, BPT, ACDC, ESP, 13B, K20.
for the RX7 thoes are great injectors as they were made for that. I am asuming you are running a B6 DOHC, so unless you have some great fuel management and a HUGE turbo like T3/T04E size your not going to need thoes. but if eventually you plan on getting to that kind of power it might be good to pick them up. but hopefully that 300 dollar price is for new ones, because you can pick up a set of used ones all day for around 100 bucks USD. and really 460's is all you really need. hope that helps ya a little. but really we need some more info to help you out.
Posted: December 12th, 2005, 11:38 pm
by mx3stylez
hey, i should have added some more info, i've got the ze swap, and am in on the group buy for the turbo kit
