car just dies??
car just dies??
My buddy has a gs and the car justdies when he is driving it...what could be causing this to happen?? Everything dies lights, motor, everything!!!
- relisys_3200
- XxantwawnxX
Ok 5 is knock sensor located inbtween the to banks under the Intake manifold runners.
12 is the Throttle position sensor..located on the throttle body.
If your prob is not those it could be the ignition coil in the disty (you have to replace the disty) Are cars have a habit of heat making the ignition coil go afterwhile. when it does your car will just shut off randomly.
- vozaday2000
does he have to charge the batter after each stall, if so check the alternator
![Image](http://memimage.cardomain.net/member_images/10/web/730000-730999/730367_31.jpg)
