I have the BPT in my 93 MX-3. The alternator that came with it caused the battery charge light to be on after startup, but off after a certain RPM.
Eventually that one died. I bought a remanufactured one from advance auto parts. Installed it myself and it worked fine. It squeeked a little all the time though.
On my way to get my car inspected it died again. This was a few days after it stopped squeeking too. So they check the car and find the alternator putting out zero volts. Great. So I had to get another alternator cause I needed my car back ASAP. Now I get home tonight and at idle, the charge light kinda fades in VERY dimly.
Is this alternator doomed to die? Does the stock Protege LX alternator not put enough juice out or what?
Alternator issues
- Cpl_Bryant
I'm not sure if i can help you, but maybe you can help me
My first question to you is: did you put the right alternator?
The second question is: can you explain to me how you managed to pull it out? because i have been trying for a few days to pull it out, but i find no room for it to get out.
lakersfan1
Re: I'm not sure if i can help you, but maybe you can help m
Pull the screws on the top radiator mount. Move the radiator back the extra inch or two that allows you. Pull the alternator. Takes an extra 10 minutes of work. Just be sure not to rub the alternator on the radiator. The stock radiator is paper thin and prone to tearing easily.alexguzu wrote:My first question to you is: did you put the right alternator?
