How do you know when your Water Pump is going?
				Juans_93_MX3
just curious
							2008 Mazda 3
1993 MX3 GS
						1993 MX3 GS
when it leaks and loses coolant, for me is did anyway
The water pump is mechanical. If the engine is running, it is working.
If it is leaking, time for a new one. Trust me, it SUCKS changing one with it in the car, especially when the one you put in leaks worse, it's 5 am, and you need it running fast. Yeah, you can tell I've had experience here
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
				killerpickle
Look out for loss of your heating unit.  Look out for your temperature guage spiking up when you slow down or stop.  Look out for any coolant loss - as you are supposed to lose very little.
							Tom Alexander
