Just had my car in for its annual MOT,
Failed on two items
Drivers Side Rear Shock Absorber - £131
and
Track Rod End needed replacd - £100
Steering re-alingnment - £ 40
MOT certificate - £ 20
With Labour comes out at £350 - Ouch
So can someone tell me what the hell a Track rod end is and what it does?
UK MOT - Track Rod End Failure
snellgrove
I believe its suspension related!
but I am not entirely sure what
sorry!
sucks that the bill is that high, but I suppose you are used to it? I know I sure am, my car happily punches huge holes in my wallet from time to time..
not enjoyable, but price you pay I suppose for a car like ours
1997, Silver, V6
lakersfan1
I'm guessing that's the term for 'tie rod end' on your side of the pond? Mine only cost $13 U.S. though and I replaced it in 20 minutes on my own. You do need an alignment after a tie rod end, though. That's crazy that your inspections look at suspension components though. Is the MOT done by independant shops, or by a government run facility? If it's an independant, they may just be trying to ream you for extra money. They tried doing that to me in the state of Nevada where the emissions inspections are done independantly, they tried telling me they could 'get it to pass' for $300. I drove straight down the block to a facility that only tested and didn't offer mechanic services, and I mysteriously passed with flying colors.
Rick Johnson
- garfy1981
Ouch on the shock absorbers !!!
I got bilsteins for about £70 each.
Pays to shop around ! http://www.provenproducts.co.uk they have been the cheapest on everything ive wanted, ( suspension, brake pads, black diamond discs )
2.5 Ze straight neck, blitz intake, mazdaspeed engine mounts, fidenza flywheel, CM II Clutch, KL-36 ecu, Magnecor 8mm Leads, Battery Relocation. Hotshot headers, 2.5 mandrel bent stainless exhaust, hi-flow cat, Speed hut dials, custom coilover set up. Custom willwood big brake conversion.
- neutral
Re: UK MOT - Track Rod End Failure
Track Rod/Tie Rod - same thing. This link gives a good explanation of its function along with a pic.UKMX-3 wrote:...So can someone tell me what the hell a Track rod end is and what it does?
http://www.carcare.org/Steering_Suspens ... _rod.shtml
-Jim
