high idle for no reason
hmm i was driving and all of thw sudden the car idles at almost 3k rpms, looked for vacum leaks..none... checled the tb idle screw..completely closed..checked cai piping..all sealed// wth o.0 I am so lost... I push the tb a bit back and it lowers the idle a bit but goes up. The tb is new and is smooth the cable is completely loose.
ill try to work on it tomorrow.
-hec
- Aston Wards
\Ok..for some reason that little scre on top of the fly itself (straight neck) must have moved but well this is what I did, put the car in test mode, readjusted the disty (lowered timing a notch on disty) Readjusted tps, and readjusted idle screw.Also i loosened the top bolt on the butterfly (curved neck does not have it) and now it idles ok.. just that it will idle like 100 rpms more then down up , down and so on. Car runs normal. Next thing on todays agenta...repace transmission passenger side seal :S shouldnt that THAT hard.
I still dont understand why one second will idle right then the next idle supoer hard and require all the adjustments i did..
-hec
