My current audio system in my MX-3
here is what i got in my car.
Deck:
JVC KD-AR800
• Power Specifications:
• Built-In Power Amplifier
• Built-In Amplifier RMS Power - 6 x 19 Watts RMS
• Built-In Amplifier Power - 6 x 50 Watts Peak
Speakers:
Alpine SPS-170A 6-1/2" Type-S Series Coaxial 2-Way Speaker
two front, two back
• 6-1/2"(16cm DIN) coaxial 2-way speaker
• Peak Power 200W
• 40W RMS
• Frequency Response: 35Hz - 30kHz
Amp:
Alpine MRP-M350 1 Channel V-Power Class-D Mono Amplifier
• 14.4V RMS Continuous Power 2ohm; (0.3% THD) 350W x 1
• S/N Ratio 90 dBA
• 24dB LP (50Hz) Crossover
MAX Power (at 14.4V,EIAJ)
• Brigded into 2 ohms : 700W x 1
RMS Power (at 14.4V,20Hz-20kHz)
• Per channel into 2 ohms : 350W x 1 (0.3%)
• Per channel into 4 ohms : 200W x 1 (0.08%)
Subs:
Kicker DC124 4 Ohm Dual 12" Comp Vented Enclosure 05DC124
• Dual 12" Vented Enclosure with Kicker Comp Subwoofers
• 4 Ohm Final Impedance
• Peak Power Handling: 600 watts
• RMS Power Handling: 300 watts
what do you think?
													Deck:
JVC KD-AR800
Speakers:
two front, two back
• Peak Power 200W
• 40W RMS
Amp:
• S/N Ratio 90 dBA
Subs:
what do you think?
						- Aston Wards
- monty73741
sounds good i would go with a sealed enclosure though
louder
							louder
Jason Danaher
Please Help Support MX-3.com
- ScooterBovine
I felt like bragging, too, so here are my specs:
Deck:
Alpine CDE-9845 MP3/WMA/CD
• Built-In Amplifier RMS Power - 16 W RMS x 4
• Built-In Amplifier Power - 4 x 45 Watts Peak
Speakers:
Alpine SPS-171A 6-1/2" Type-S Series Component Speaker System
two front, two back
• 6-1/2"(16cm DIN) with 2-way crossover
• Peak Power 250W
• 8-50W RMS
• Frequency Response: 35Hz - 35kHz
Amp #1:
Alpine MRP-F240 4/3/2 Channel V-Power Amplifier
• 14.4V RMS Continuous Power (20Hz to 20kHz) into 2ohms; (0.3% THD) 50W x 4
• S/N Ratio 100 dBA
• Per channel into 2 ohms : 50W x 4 (0.3%)
Amps #2 and #3:
Jensen JXP460 2 Channel Amplifier
• S/N Ratio 100 dBA
• 12dB/octave Crossover
MAX Power (10.-15.6v allowable)
• Brigded into 4 ohms : 230W x 2
• Per channel into 4 ohms : 230W x 2
Subs (2):
Kicker CVR10 4 Ohm Dual 10" Comp
• 2 or 4 Ohm Final Impedance
							Deck:
Speakers:
two front, two back
• Peak Power 250W
• 8-50W RMS
Amp #1:
• S/N Ratio 100 dBA
Amps #2 and #3:
• S/N Ratio 100 dBA
Subs (2):
No more MX-3.
						- PATDIESEL
2 ohm loads will wear out the speaker and amp faster. Most good brand speakers and amps can handle it, but just a suggestion to prolong thier life.
Other than that nice set-up, for a NEWB!! hahaha
LOL, jk
LOL, jk
