Fuel Pump Questions
Bradmx32003
Fuel Pump Questions
If the fuel pump is working you can hear it working correct? If I remember you can hear a very slight hum come from it, and you can clear hear it shut off. Any tests I can do to see if my fuel pump isnt working?
Red 1992 Mx-3 GS, all stock.
hgallegos915
you can actually hear a humming noise in the engine bay. the injectors getting filled with gas. Check your engine fuses if its not working. If its a gs i got an extra pump.
-hec
Bradmx32003
- jaydog5678
Bradmx32003
snellgrove
- PATDIESEL
That is where it is. There is also a fuel pump relay in that same fuse box. I know this thread is over, but that could also be a problem to check for if the fuel pump doesn't seem to be working.
