Heres what I have...
Any help is appreciated.
(Sorry, what are you refering to as the clock spring?)Custommx3 wrote:Im curious....
If hooked a button directly to the plug in the clock spring.. would it activate the horn.. if so I can eliminate the black ring on the bottom of the hub.. and everything would be fine.
Ideas?
I'd like to see that application Mike (I know, it's in getting it's paint job - nuts). I just picked up a MazdaSpeed Steering Wheel (SWEEEEEET) and before I install I thought I might dig up an old thread to help me along. Has anyone installed a MS steering wheel? If so is it still possible to retain the cruise control on the side hub part of that steering wheel? I realize that it might require a homemade mouting bracket or drilling into the side of the hub or both but a little guidance before I get to the point of no return would be nice. Even any info wrt retaining the cruise control onto an after market hub/wheel might even help.Nd4SpdSe wrote:I did the same thing, chopped it off flush, I only ran the one wire for the horn cause i relocated my cruise control controls behind the ignition
I can't recollect how it looked. How surprised, do you mean there's a huge box or circuit board that's inside the original hub?Nd4SpdSe wrote:I though you already took a peak at my controls setup...I'd be more than glad to take a look at it, we could easilly work something out, I know that wiring really well, but you'll be surprised as the size of the box that the buttons on the stock wheel are connected to...
Ya, got it from Marlon. You mean to say that there's not enough space inside the MS wheel hub to accomodate? If there is, I'm not worried if all that's required is to cut a small slot along along the steering wheel edge of the hub to mount the CC switch.Nd4SpdSe wrote:After finding the pics of the wheel (i believe you got it from Marlon, right?), There will be no direct way to mount the controls on the wheel
