my car is idling really weired, from 400rpm to 1500 rpm.... dont thinbk its a vac leak, could it be because i have no air filter in\........... i wounder?
i will run a check code and see, but can i get codes for things that may not be broken, in that i mean other pronblems causing the falt code.... my engine light stays on all the time...
idle
- JWMX3
Re: idle
you have no air filter ???????? umm,.... i suggest you put one inmasterklze wrote:my car is idling really weired, from 400rpm to 1500 rpm.... dont thinbk its a vac leak, could it be because i have no air filter in\........... i wounder?
![Image](http://img40.imageshack.us/img40/7481/avatarmx.png)
