on the 5 speed tranny on the 1.8 v6
my question, there is 2 sensors on the tranny, the one by the filler hole, and the one by the drain plug, what is the one by the drain plug, because the wires are broken off.... and they are both wires going to the sensor are both green, with no other indication so i dont know how to re-wire it....
i am assuming its the revers lights?
tranny sensors
- XxantwawnxX
Back up light switch...i think....almost sure... yes.
