Your dream ze rebuild
- MX-3 Money
I'm bored and thinking about what I could do to my ze, So lets have some fun. Say that you had a ze just layin around and you wanted to rebuild it, what would you do to it? Up the displacement? Change the compression ratio for a turbo/sc? New cams? Or just put in a whole bunch of bulletproof parts so she'll be strong. Or all of the above lol, and moneys no object. Now after you list what you would do, take a guess at how much power you would create and I guess how much money you think you'd spent. So just have some fun with this cuz I'm interested to see what ideas some people come up with.
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
- Kokiriwave
klze
bore and stroke to 2.7
bulletproof with upgraded H beams, pistons, ext
sequential turbo, t25 & t04
I want MAZDASPEED!
MY WEBSITE:: http://kingmx.net
- fry_81
lol dittobmwm3guy wrote:my dream KLZE? see babybluemx3's motor and there she is.
- MX-3 Money
I am half through my KLDE build right now.
Forged 331 stroker mustang rods, .11" overbore (2.5mm) to make it a true 2.6L, 300zx twin turbo pistons for 9:1 compression. New bearings, nissan rings, duratec valve seals, and some mazda gaskets. Done.
Good for reliable 450-500 whp, more if I want to push it further.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
Spink, here's my thoughts.
I'm using are stock 300zx twin turbo cast units. This takes a lot more tuning and are much easier to break if you detonate, so in essence the engine will not be "bulletproof" however, when tuned correctly the rods and pistons will have no issue at the 450-500 hp level.
IF you plan on running nitrous or are not very good with tuning, I still would suggest forged pistons.
I've done a lot of research before I decided on my setup.
If you are looking for forged rods/pistons, take my suggestion for the cheapest route.
Use forged mustang 347 stroker rods (not the 331 like I'm using) off ebay. Search for TMD, they sell a set with ARP bolts on ebay for $150.
They use the standard .912" wrist pin for ford V8's and are 5.4" long vs. the 5.426" of the KL. The big end width is correct to fit in the crank, and .40 over 302 ford rod bearings should fit without grinding the crank (make sure you plastigauge this though)
Send in one of the rods (youll have 8, so no worries there
) to brc. http://www.brcpistons.com
They are great guys that know their stuff and make some kick a-- forged pistons.
Also send in your stock rod, and the stock piston. Tell them to make a piston in the same compression (or a bit lower if you want) to accomidate the larger ford wrist pin. These mustange rods also are bushed so you will want them to make the new pistons set up for full floating with c clips.
Last I talked to them, they charge $505 for 6 custom forged pistons, and their work is excellent. You won't be disappointed.
Theres another guy I know who got 6 custom pistons, wrist pins, clips, and rings for $700 shipped from them. Their prices are great.
Not to mention, you can have them make these in stock bore size to save yourself the $$ on boring.
So there you have it, forged pistons and forged rods for under $700 or $800.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
Hey rebel, how much have you spent on getting your engine built?rebel2k4 wrote:Spink, here's my thoughts.
Send in one of the rods (youll have 8, so no worries there) to brc. http://www.brcpistons.com
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Projected cost right now is about $1300. This is for all machine work (I shopped around) new rod and main bearings, thrust washers, custom wrist pin bushings from crower, forged 331 stroker rods, used stock 300zx twin turbo pistons and wrist pins, ITM rings, fel pro head gaskets, fel pro valve cover gaskets (both I got for a song), and new seals, including duratec valve seals. I'm not doing cams, valve jobs, or porting. This is just for a basic rebuild but with parts to make it hold 450-500 whp reliably.Juans_93_MX3 wrote: Hey rebel, how much have you spent on getting your engine built?
I already have purchased a few of the items (forged rods and the pistons) and I'm in the process of tearing down the old motor to take it to the shop.
I am doing all assembly, research, and sourcing of parts.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
