lakersfan1 wrote:
leave your current ECU in the car. Only replace the K8 engine with a KLZE and the JE50 air sensor with a KL02 air sensor from an American V6 model car.
No good, on an K8 OBDII Harness, something like 60 of 68 pins are wrong. I have all the pinouts and color codes for all the K series engines.
My car is a 96 GS aswell, i havent decided what im gonna do yet. I have tried to cover all the bases for when it is time.
I have:
- 97 PGT MTX ECU
- 94 Mazda MX-6 LS MTX ECU
- 94 Mazda MX-6 LS MTX Full Harness
I tried to find someone to make me an in betweener but they said it would change the resistance on things which would not be good.
You can keep your car OBDII if you can make all the sensors happy.
But it seems like swapping the whole harness will be the way to go.
On another note...what kinda mods are you planning? I heard through the gossip grapevine that OBDII can actually de-tune you mods over time.
How much of that is true...i dont know...but is sounds plausable.
g/l
