Engine Test
Engine Test
Hi there,
Had a quick question regarding motor test. I am going to get a ZE motor this weekend and was asking the shop what sort of tests they do on the engine. And they said they don't do compression test as it's not realiable on a cold motor. Instead they would be doing a leak down test to make sure the motor is good.
Just wanted to get your opinion on this if it's a load of bull or if it's legit. Thanks in advance for your assistance.
Uday
Uday
Friends are just enemies who lack the testicular fortitude to kill you.
I'm a 2min man in a 1min universe
94 GS - KLZE, Spec2 Clutch, Fidanza 9lbs FW, 2 1/4 full magnaflow exhaust. 145WHP / 147WTQ
- Tunes67
A leak down test is generally more reliable than a normal compression test.. their reasoning about not doing a compression test on a cold engine could be valid. Especially on engines with aluminum heads. Heat causes expansion and aluminum expands quite a bit.. so when the engine is cold, everything would be at its tightest point and a simple compression test might not reveal problems that a leak down test might.
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
- PATDIESEL
I'd ask them for a copy of the leak down test results. That way if you get the motor, install it, and it is crap you can have another shop do a leak down test and make sure it is not a compression issue. If it fails the test then you have recourse against the seller of the motor.
Oh ya there was no doubt I was going to get everything in writting. Also I told them once it's in and everything I would bring it back in for the compression test regardless and they have no problem with that.
Now all I have to do is get the KL3x ECU and a MAF
- FrankenMazda
BLATANT THREADJACKING
Im really sorry about this but .... I cant post in buy/sell.
PATDIESEL, why havent you repponded to my email?
You responded just fine, until you received my $158, 10 days ago.
That has me troubled.
Mixup? Fine, ship my stuff. Respond to my email chris.dunster@gmail.com.
I have motor swap madness, Ive lost my mind and have never been happier
I do have a MX3..however I am getting the curved neck intake manifold and with the KL3x ECU would need to change my JE-50 VAF as it won't work with the ECU/Intake combo. At least that is what I have been lead to believe and read thus far.
But if I am mistaken please do let me know.
no just use the je50 vaf. The kl31 or 36 ecu use a je50. The ecu is actually for a straight neck but works fine using the curved neck just the vris points would be off.Selecta wrote:I do have a MX3..however I am getting the curved neck intake manifold and with the KL3x ECU would need to change my JE-50 VAF as it won't work with the ECU/Intake combo. At least that is what I have been lead to believe and read thus far.
