Yeah nothing has changed since the last time you saw her....most recent change is the window slim visots(love them.) She need a paint job, and im thinkin of going black to match the visors and such(my old mx3 was black too). but yea.
EDIT: oops i did change sumthing..i cut out the factory grill cause i just wanted a big hole : P and i took out the ac condencer cause i have no ac...to make room for my future intercooler ( PFFT not gonna be turboed for a long while lol)
OH and dont mention the mis aligned hood lol...trying to fx that atm : P
Your MX-3 is lookin very good If you can find some rear mudguards it would top it off. I kinda like it without the spoiler but it might look just as good with one. Than again thats totally up to you!
if i can find me some sides like i want, ill hook ya up with some teal rear muds
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
