Hello,
I have a 1.5 b5 engined  az3, chassis ec5sa.
I'm looking for info on an engine swap. Is there a larger engine that would fit straight in or is it going to be more hassel than it's worth.
Thanks.
						Engine swap info
i just did a 1.8l bpt swap into my car not too difficult it took my brother and i three  days to have everything installed
							1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
						you can use your gearbox (fseries) dont abuse it i am using mine still its been a few months nothing broke, you will eventually nees a gseries box. the engine comes from a gtx mazda 323, you need the ecu, i used the gtx engine harness and ecu just had to get the fuel pump wire switched you need a fmic anything else look on the site there is lots of info, if u dont get the answers u want just let me know
