Klze Speed limiter Need help
				wheelmanmx3
The wiring harness from my 1992 GS harness does not match the colors of the wiring diagram that was given on the site. I checked it and i cant find out the wire to cut to remove the speed limiter. If anyone has any idea on which wire to cut please let me know. I used the stock GS k8 harness on the ZE. Can anyone let me know please. Must go past 120 mph.
							Its not  about how fast it goes, but about how well you drive it when it goes fast.
"Wheelman"
						"Wheelman"
Re: Klze Speed limiter Need help
That's the spirit! :2thumgsupwheelmanmx3 wrote:Must go past 120 mph.
The speed limiter is in the ECU, which ECU do you have?
				wheelmanmx3
I have a Kl36 ecu
I would cut it, but the color does not match the one that is on the diagram I have the same print out. Should i just cut the wire that matches the location of what is described in the diagrambmwm3guy wrote:
Cut that wireIt is coming out of the medium sized (22 wires) plug going into your ECU and the diagram is as if you were looking into the plugs on the ECU (wires are coming towards you).
"Wheelman"
						"Wheelman"
- jschrauwen
This is what I got from Black Magic:
http://www.mx-3.com/phpbb2/privmsg.php? ... ad&p=16380
Same as bmw3mguy said, more or less.
				hgallegos915
jsc... lol you popsted a link to your private messages..didnt work.. anywho so um If i wanna blow my k8 I would  just remoive that wire and it would not have a limiter or what?? o.0
							-hec
- ccreech
I don't think that this wire is the rev limiter...I believe that it is just a speed limiter...Not sure...So you would have to be going like 150 to blow it up but yeah, you could blow it up...if you plan on trying please post videos titled 150 Mph Detonation
						- XxantwawnxX
hmm i have the same set up...but i can wind it out to 137 np... wonder why.
				hgallegos915
ok so by cutting that line... that removes our speed limiter? It wont damage anything else? I mean I dont wanna blow it on purpose..but iut be nice to be able to go a bit faster with no speed limiter. Can someone confirm that by removing that line..my speed limiter will be gone?
							-hec
- jschrauwen
From what I have been told by Black Magic, that's the pin, although I will cut my wire and not the pin. I've already confirmed the speed limiter a number of times with the KL31 ECU and it cuts out at about 185 kph.hgallegos915 wrote:so by cutting that line... that removes our speed limiter?
				hgallegos915
Im going to try this on the k8.. I doubt the gearing will even let it go over 130 and well if it blows ill post pics
 of course this is in a "controlled" environment.. so dont go erasing my posts
  also I do not specify what a "controlled environment" is
  should be fun. I hope that by removing that wire I wont get a cel light or any side effects.
-hec
							-hec
-hec
