oil capacity
AZ-3,1498cc,UK
oil capacity
Just changed my oil and put in 4.5 litres does that sound like the right amount? Also i put in 5-30w castrol magnatax synthetic oil as my engine ticks a bit. I live in the U.K where the climate averages between 0-25 centigrade, is 5-30w grade oil more for a climate below 0 degrees?
V6 MX-3, Black, 17" gunmetal chromes with 205/40/17.
Now gone: Autozam AZ-3(Jap spec MX-3). 91, 1498cc DOHC 120bhp as standard. Manual, A.C, 17" black chromes with 205/40/17. Stainless Steel Exhaust,Pipercross Filter, Eco-tek valve, Strut brace, Racing steering wheel.
I believe its 4.2
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
AZ-3,1498cc,UK
Im confused: in the online tech manual it says oil capacity:
Total (dry engine) = 4.9 L
Engine oil replacement = 3.7 L
Engine oil + oil filter replacement = 4 L
so how much oil is needed in an oil change?
according to Chilton's
engine w/ filter (qts) = 4.2
AZ-3,1498cc,UK
so is it worth draining some out if i put in 4.5L?
