im laggin mid to high end power. it seems like once i hit top of 3rd and shift to 4th gear it just doesnt wanna pull no more. anyone know why this is happening? oh this is a 1.6l dohc B6DE motor.
Traves
laggin mid to high end.
ive been having the same problem...seems like it has no power in 5 th
http://www.etuner.ca
Exec etuner member
Exec etuner member
- neutral
Lil more info might help narrow it down.
1. Did you have "pull" in the upper gears before and now find that expected performance has degraded?
2. What kind of intake set-up you guys using, stock, K&N panel filter, CAI?
3. When you say it won't pull above 3rd or 4th, do ya mean you can't get rpm's to increase responsively or do ya see rpm's go up in those gears but speed doesn't increase like you'd expect?
-Jimi just bought the car, im running a short ram intake, but even before it nvr pulled in 5th, i hit the gas and barly any increase in the rpm...is the car just weak in 5th, or is it something else. all of the other gears seem to work good adn my motor is the 1.6l DOHC.
Exec etuner member
Exec etuner member
jimishadow
- Typhoonk
1. Do a tune up. Plugs, rotor, wires
2. Check intake for leaks
3. Have a mechanic test drive your car (I bet your clutch is on the way out)
PM for info
PM for info
