I've seen several posts about this, wanted to post a helpful hint...
Several people have had problems removing the wheel bearing locknut (as did I)... I've seen posts of people jumping on breaker bars, not safe and probably not good for the suspension.
Better idea, guaranteed to help in nearly all cases....
1. Soak with penetrating oil (JB works well), maybe apply twice over 1/2 hour period and let sit.
2. Use a large 1/2" drive minimum driver with a long (2ft) bar, or a breaker bar extension.
3. Try to remove by strength first, if that doesn't work...
4. Use a floor jack, much safer and more reliable than jumping or other methods....
- simply align the end of the wrench/bar so that it's a few inches above the ground (but angled down) when lifting in the upward direction.
- Place the floor jack under the end of the bar, and carefully apply pressure to the end until it is securely seated on the jack.
- Slowly and carefully jack the wrench "up", applying pressure to the bar (watch for slippage or lateral movement, back off and adjust as need be).
Using this technique takes all the "work" out of the equation, my rear locknuts lifted the suspension about 4" before finally snapping loose, and the breaker bar had about 1" of bend in it at the time (a bit scary, use a bigger bar than I used, safety goggles, and stand clear of possibly breakage). Impact wrench did nothing to these bolts, although that's worth a shot first (once I cracked them loose, I used the IW to remove them the rest of the way). Reinstall to 230ft/lbs (my torque wrench topped out at 150, but was rapidly increasing about 20ft/lb per 1/16 revolution, so I cranked it another maybe 3/16 rotation around (could feel it getting much stiffer, put my full body weight onto the end (230, coincidentally, but at about 1.5ft, so more than enough) and pinned the slot in with a chisel, good to go.
Unless your nuts are so tight they are strong enough to pickup the car itself, this should guarantee a good, easy removal. (I'd probably get a new axle assembly in that case).
Wheel bearing removal tip
Black 94 MX3 GS loaded except ABS, Original owner (139kmiles, bought fresh off the delivery truck(watched them unload it at the lot still wrapped in shipping plastic), KYB Struts, Brembo rotors, KVR Carbon Fiber pads, Dolby Digital EX/PLII/DTS-ES/Neo6 decoder, DVD player, 7.1-discrete channels, 550watt 5.1 amp plus bridged 140-watt 2-channel, 4x6.5"-3-way; 2x6.5" 4-way centers (front/rear) (all Pioneers), MTX 10" sub), Sony CD receiver, more to come, has survived $24,000+ US in damage in it's lifetime and still rolling (anyone have a straight 1994 U.S. spec right front fender to part with?)
- neutral
Re: Wheel bearing removal tip
Good tip, thx for that.christexan wrote:...Unless your nuts are so tight they are strong enough to pickup the car itself, this should guarantee a good, easy removal. (I'd probably get a new axle assembly in that case).
My nuts are pretty damned tight & strong but probably not so much as to pick up the car itself but, who knows...
![Image](http://i116.photobucket.com/albums/o32/jimfyp/picnic4.jpg)
Im the jumperchristexan wrote:...
![Cool 8)](./images/smilies/icon_cool.gif)
Ya using the Jack is a good idea, prob would have worked. I never thought of it, i spent half a day trying to get it off, broke my 2 ft 1/2 inch breaker bar and my 1/2 inch ratchet with a 10 foot pole on it.
It took about 20 min of ratteling with the impact gun b4 my fat bastard friend could get it loose standing on my new breaker bar.
There was alot more than a 1" bend on it
I have had these changed b4 at a shop, so im thinking they must have put the nuts back on alot tighter thatn they should have.
- Tunes67
Ok.. I dont know if this tip would work for this situation.. but one little trick I have found when I needed higher torque than a standard breaker bar would give me, is a Floor Jack Handle. Not your cheapy ones.. if you have a good 6 ton or more capacity floor jack.. the handle is usually a two piece handle.. take the bolt out that holds the handle together.. and slide the handle down over the breaker bar. I havent met a bolt that this combination couldnt break loose.
Not only does this give you additional strength & torque.. but it also protects your breaker bar at its weakest points. Give it a shot if you have a chance.
Tunes67
Tunes67
