Help! Call out to ZE owners! '96 MX-3 with ZE. ECU problem?
Just bought a very nice MX-3 with ZE but have some issues with it.
1) Burns insane amounts of gas
2) Gets a little sputtery when easing on or off gas pedal.
My best guess on cause of problem: stock 1.8 ECU.
If I'm right, what are my options to remedy the situation in light of this car being an OBD2 setup?
- jschrauwen
Numerous threads on ZE/ECU issues via search function. 1.8 ECU - ya that will probably be a good start to try and replace with KL31 or KL36 ECU. Like myself, MX6/626 ECU could get you by in the meantime.
Are you using the stock je50 vaf? by the sounds of it you are and that is your problem. You need to get a vaf from a probe, mx6 or 626. They are called kl02 i believe. And just keep the k8 ecu. You are right you cant use a ze ecu because you car is obd2, you could to convert to obd1, but that would take insane amounts of work.
The KL02 will give the ECU different information on the amount of air entering the engine, which the ECU will try to adjust the amount of fuel to match. Also, you'll probably want to get an adjustable fuel pressure regulator with that setup so you can lower the pressure to your fuel system. This will help with fuel consumption and rich conditions. You'll probably want to have a performance shop set the fuel pressure for you as they can take readings on the air/fuel mixture and adjust accordingly.
Any recommendation on which adjustable fuel pressure regulator to get?
Once it's in there and I get a shop to make adjustments, I don't have to worry about it anymore, problem solved?
If I go the adjustable fuel pressure regulator route, I should still get the KL02 vaf to be running nice and smooth right?
Will these changes harm performance of the car?
Been there done that, use a kl02 vaf sensor from a probe or mx-6. Buy a universal fpr, any, just as long as you can set it to 40-43psi and your set to go. Only your vris will be off. A customer with the same setup had it on the dyno and pulled 194hp. By the way, the vaf is the sensor between the airfilter and your throttlebody.
Bastian
Bastian
17 inch bba racings rims, apex lowering springs, laser muffler, boost steering wheel, mazdaspeed seats, black altezza's, testpipe, oh and a polished klze with an upgraded clutch and a kl36 ecu.
- XxantwawnxX
Ze, k8 ecu, k8 vaf..been working fine for me.
[quote="Overclock"Noticed the car also shakes quite a bit for a few minutes on start up. Should I attribute that to the vaf and fpr as well?[/quote]
That could be something else. Is your valve cover gaskets leaking? Pull the plug wires and see if any of them are wet with oil, and pull the plugs and check for wear. If you do have oil in the spark plug well clean it out and replace the gasket. I have the same problem occasionally.
