colour of vics plug??
Posted: February 16th, 2005, 11:21 am
by Joey's mx
Hey can someone tell me what colour the plug for the vics solenoid is?? Also are all the solenoids the same??(can the prc solenoid be used with the vics setup+wirring??)
Posted: February 16th, 2005, 1:50 pm
by Joey's mx
this is for a 94 dohc (b6ze)
Posted: February 16th, 2005, 4:51 pm
by Joey's mx
Can anyone help me out??
Posted: February 16th, 2005, 5:27 pm
by Tunes67
Heh.. tell me where the plug is and when my car is out of the shop (today or tomorrow) I will look and let you know.
Tunes67
Posted: February 16th, 2005, 5:45 pm
by Joey's mx
it is beside the fuel rail(passenger side) you might have to follow the vacuum lines form the vics around the back of the intake manifold to the solenoid..it should be either green, white or brown!!! Again you will have to follow the vacuum to know which is which!! I really appreciate it..Thanks!!!
Posted: February 16th, 2005, 6:36 pm
by Tunes67
No sweat man.. and the shop just called.. my car is done.. should have a post back here for you in a couple of hours (heh.. test drive ya know)
Tunes67
Posted: February 16th, 2005, 7:04 pm
by Joey's mx
Cool thanks again....hope she runs good!!!
Posted: February 17th, 2005, 2:34 am
by Tunes67
Well Sweetness is back on the road.. shop didnt time her very well and I will have to adjust that and the idle.. but the power is good and the idle is smooth. I did check on the VICS solenoid placement. I was able to eliminate the brown solenoid. From looking in the manual (pg F1-110) at the placement of the solenoid, I would say it is the green one. I'd bet on it truthfully.. I just wouldnt bet a lot
Hope this helps you man.
Tunes67
Posted: February 17th, 2005, 9:05 am
by Joey's mx
Cool it sure does thanks alot.....really appreciate the help...good luck with the timing and the idle!!
