colour of vics plug??
Hey can someone tell me what colour the plug for the vics solenoid is?? Also are all the solenoids the same??(can the prc solenoid be used with the vics setup+wirring??)
- Tunes67
Well Sweetness is back on the road.. shop didnt time her very well and I will have to adjust that and the idle.. but the power is good and the idle is smooth. I did check on the VICS solenoid placement. I was able to eliminate the brown solenoid. From looking in the manual (pg F1-110) at the placement of the solenoid, I would say it is the green one. I'd bet on it truthfully.. I just wouldnt bet a lot
Hope this helps you man.
Tunes67
Tunes67
