Muffler to go with 3 inch exhaust
Mx6lsT
Post by Mx6lsT »
was thinking about getting this one
http://www.hottexhaust.com/detail.asp?product_id=14850
magnaflow muffler 3 in 4 out
probably 125 shipped any suggestions
i'm not big on ebay universal crap
neutral
Post by neutral »
That one looks like it lists 2.25" inlet instead of 3". What size engine is in your ride? 3" is huge and will possibly cause a drop in low-end torque due to an overly large pipe = lower exhaust velocity, unless you are turbo'd.
Image -Jim
Mx6lsT
Post by Mx6lsT »
i'm turbo
I thought this one was 3in 4 out
i'm looking for one that is 3 in 3 out
Steeb
Post by Steeb »
neutral wrote:That one looks like it lists 2.25" inlet instead of 3". What size engine is in your ride? 3" is huge and will possibly cause a drop in low-end torque due to an overly large pipe = lower exhaust velocity, unless you are turbo'd.
i believe this is the forced induction section
Steeb
Post by Steeb »
ill add, most magnaflo's sound good on any car with more than 4 cyl. my friend has a magnaflow on her c class, it sounds pretty nice but it's not the quietest and it does get quite loud. longer mufflers will be quieter and shorter mufflers will be louder.
post a vid or sound clip when u get it done :2thumbsup:
Return to “Forced Induction”
