Spark Plug wires Help Me!!!
Posted: February 10th, 2005, 9:11 pm
by Trevor
I want to get a good set of performance wires for my ze swap. I went to "Automotive Wearhouse" and all they had was "reactive" and "taylor" wires. Anyone use these? or can lead me in the right direction. I Tried to find Accel cause I heard they were good but no one can get them for me.
HELP GUYS!!!
Posted: February 10th, 2005, 10:36 pm
by mxmaz
did you try asking for accel's for a probe gt, 626, mx6 or millenia. They will all work.
These are good wires
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WD1V
Posted: February 10th, 2005, 10:43 pm
by mitmaks
i think gro harlem has them and theyre too long, too long of wire=looks funny and you losing hp, spark has to travel through longer wires
by mazdubber
Get the MSD 8.5 mm's for an MX-6/Probe. Well worth the money. Got mine from Jegs.
Posted: February 10th, 2005, 10:44 pm
by mazdubber
mitmaks wrote:i think gro harlem has them and theyre too long, too long of wire=looks funny and you losing hp, spark has to travel through longer wires
They're supposed to be routed around the IM.
Posted: February 10th, 2005, 10:48 pm
by mitmaks
but are they same lenght as for k8, anyone know, if so I might get some, my stock NGK's been good but I think i should be replacing them soon
Posted: February 10th, 2005, 10:52 pm
by mazdubber
The MSD's are MX-6 sized. They go along the top of the front valve cover. Up the left side of the IM, and across to each plug. Like this...
![Image](http://www.projectmazda.com/host/x/ze2.jpg)
Posted: February 11th, 2005, 4:45 am
by IanL
Unless the igniter and coil performance is really marginal, the extra length will make no discernable difference - after all, it works fine in a Probe. You could double it and not notice, as long as the wires were in good condition.
Posted: February 11th, 2005, 4:37 pm
by Gro Harlem
Fraid not dood. The wires I got are fine
I measured the ohm's between EVERY wire when I first bought them just so I'd know
The short wires were 250-300 ohms and the longer ones were 700-800 ohms.
The peice of s--- NGK's I had on the car before were 2000-3500 ohms.
I'd say thats a good difference right there.
BTW: with a curved neck manifold I would suggest you NEED the long wires.
IF you get the stock MX3's with the KLZE curved neck the wires will be squished between the top of the manifold & the hood. That is how I had my accels routed before & parts of the red silicone jackets are all smudged up and crappy now & parts of the silicone were almost rubbed down to the fiberglass inside the wire
And don't buy NGK's. Their quality is really lacking these days. They used to be great, but now they seem to fall apart pretty fast. The crimpers they use to keep the plug boots on don't hold up well.
Posted: February 11th, 2005, 7:34 pm
by pinkmx-3
i got the probe kind and after taken the stock ones off i forgot how they are suppose to go on cause these wires dont have numbers on them. even if it did i wouldnt be able to tell what hole it went into.............
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
Posted: February 11th, 2005, 7:49 pm
by RizzeRocket
hahahaha just put em on the way u think they should go , some miss firing wont hurt at all
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Posted: February 12th, 2005, 4:06 am
by IanL
Gro Harlem wrote:Fraid not dood. The wires I got are fine
I still say the effect on performance between 300 Ohm and 800 Ohm will not be noticeable. How many Ohm is the plug gap - probably over 1 MOhm!
Btw, measure the new wires after say 1 year - I expect they will be about the same resistance as the NGKs. The wires are resistive to reduce RFI (radio interference), and it increases with age. If you live out in the sticks, try solid copper wires and see if there's a difference to the engine - unless you have a problem with the igniter or coil, there won't be.
Posted: February 12th, 2005, 9:36 am
by XxantwawnxX
Ive never bought wires for an mx3...i only buy probe wires. So much cheaper : P
Posted: February 12th, 2005, 10:47 am
by 93-Spec-Edn
XxantwawnxX wrote:Ive never bought wires for an mx3...i only buy probe wires. So much cheaper : P
Would they fit the K8 fine? Is the performance the same and did u buy them from the dealer?
thanks
Posted: February 15th, 2005, 1:19 am
by Gro Harlem
IanL wrote:Gro Harlem wrote:Fraid not dood. The wires I got are fine
I'll try to pop one off and measure the resistance now. The wires are over a year old right now.
I got an ohmeter w/me in my car so it won't be a prob. I might do it tommorrow if i remember.
