What are the 1/4 times for our GS MX3s?
Juans_93_MX3
Manual or Automatic, dosent matter.
Im just wondering
Im just wondering
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- XxantwawnxX
I only tracked mine with the ZE wich was a 14.4 but i think a normal GS would have to run 16 and up.
This topic would be better off in the track section. Ok with that said
16 and up is a good estimate. my personal best at moroso is 16.4
but let me break in this new clutch properly and see if I can't better that.
I'm refering to the manual by the way. I would add 1 second to the times for the auto.
Andy P. 93 GS
Andy P. 93 GS
Juans_93_MX3
Its pretty awesome times for the KLZE.
Imagine putting a turbo on it, full exhaust, take out 200 pounds off the car and hit 13.2s and no Mustang or Camaro would be able to touch you
LS What?
LS What?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
I know this is a bit of topic but have a squiz at this page its the
class im building the mazda up to race in as you can see there are
a few quick cars..
http://www.championdragway.co.nz/night/nsdw3/C3EDAT.htm
Matt
a few quick cars..
Matt
- XxantwawnxX
Oh and on my 14.4 mx3(black one) my car was about 400-500 pounds. lighter...exreme gutting.
TsiMiata
To high as in to slow? or to quick?fieval79 wrote:see, I don't see how the times are so slow for a 1.8 Gs.....
I used to own a 94 4 banger, and my best time was 16.3 with it.
I know own a 92 with a kl-de .......and I have yet to run it..... I also can't believe a ze only gets around 14.4...... just seems too high.....
91 Eagle Talon Tsi AWD *RIP*
Macen
According to this calculator, the 1/4 mile time is 15.52 ( 1.8 K8 ). 14.6 with my 2.5 KL-DE.
http://www.rx7.com/accel_calculator.html
TsiMiata
The MX-3 when run by magazines when it was new ran 16.8. I ran the different engines in cartest & got a lot higher numbers. After some head scratching I figured out where you went wrong with the RX-7 calculator. The Hp is the wheel Hp, not the flywheel. Drop the advertised Hp #'s by about 30 and that will get you pretty close to wheel Hp. The weight you put it in should be ~2700lbs, since it needs to include the driver.
Here are the cartest #'s-
Stock 1.8= 16.7
KLDE= 15.3
KLZE= 14.8
And the RX-7 calculator #'s with estimated wheel Hp-
Stock 1.8= 16.7
KLDE= 15.59
KLZE= 14.68
Stock 1.8= 16.7
KLDE= 15.3
KLZE= 14.8
Stock 1.8= 16.7
KLDE= 15.59
KLZE= 14.68
Juans_93_MX3
