New throttle body....
I was wondering if they make a performance throttle body for the K8 engine?
1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
![Image](http://i7.photobucket.com/albums/y296/Legato626/supra%20pics/P1010277x-1.jpg)
- babyblueMX3
corksport does...or you may want to contact PRO or CZT to check if they can make it
RIP 400whp ZE-T MX-3
throttle body
corksport has one, where i never seen one on there website can you give me a link?
- babyblueMX3
mmm I'm sure I have seen it on there sometime ago..maybe they stop making it..try to contact them and ask them
CZT Throttle body
I cant find any info online about these throttle bodies can someone give me a link please?
f--- Corksport!!!!!!!!!!!!!!!!!!!!!!!!!! Order it at precisionracingonline.com
Corksport is wayyyyyyyyyy overpriced!!
Bastian
Bastian
17 inch bba racings rims, apex lowering springs, laser muffler, boost steering wheel, mazdaspeed seats, black altezza's, testpipe, oh and a polished klze with an upgraded clutch and a kl36 ecu.
- papa roached
get a millenia TB, its 60mm instead of the K8s 55mm and should be more than enough for the K8
where can i get one!
The part of the site to look at the CZT TB doesnt work. And millenia TB where can i find info and prices on that TB?
