klze filler neck
klze filler neck
I need to know, if the third wire for the sensor on the k8 coolant neck is not hooked to the klze will anything bad happen to the engine. I have already replaced the timing belt and removing the cover is a *****. Can any of you guys enlighten me about why there is 3 sensors on the k8 and 2 on the KL
the third sensor is the fan thermosensor, the only thing it does is shut your fan on and off when the temperature fluctuates, otherwise if it is not hooked up, when your engine gets up to temperature, the fan just stays on all the time, and if you have the sensor hooked up, if you look under the V6 FAQ you find that you can set your TPS switch with the fan sensor hooked up, check it out and post if you need any more details.
You know the world is going crazy when the best rapper is a White guy, the best golfer is a black guy, The Swiss hold the America's Cup, France is accusing the US of arrogance, and Germany doesn't want to go to war
- papa roached
you could also just swap the whole filler neck setup off your K8 onto the KL-ZE
Re: klze filler neck
Actually, there are 3 sensors on all early K series for export, and two on later; I've checked Millenia, MX-6 and MX-3. The change date was mid '93 to mid '94, depending on model.wheelmanmx3 wrote:.... Can any of you guys enlighten me about why there is 3 sensors on the k8 and 2 on the KL
Can't say if /when JDM production changed.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
