how can i tell if my cat is clogged?
MarkMoore
Post by MarkMoore »
1992 GS/RS Mutant Automatic
Custommx3
Site Administrator
Post by Custommx3 »
Whens the last time u had to change the litterpan? :D
if its clogged the car wouldnt run, if its partly clogged, you smell a rotton egg smell.
DJsMX-3
Post by DJsMX-3 »
You take it out and put your lips around the flange in one of the ends, then either suck or blow... If air passes either way it isnt clogged :wink:
Ahh sorry couldnt resist it He he please dont do as described :shock:
1992 MX-3 V6 Z1 Arbet VIII 17 x 8" -35mm Proracing Springs on KYB Sports, Corksport Strutbars, Brembo Cross Drilled & Slotted, Goodridge SS Brakelines, Corksport SS Clutchline, Mazdaspeed Enginemounts & Front arm bushings, All SRD bushings in shifterlinkage and cross member, Pacesetter Shortshifter, KN Conefilter, Custom SS Exhaust, Stereo Oldschool Goodies Denon & Phoenix Gold, Boston Pro & Cerwin Vega and lots of other small goodies
93SOHC
Post by 93SOHC »
theres a kit you can get for pretty cheap from otc tools or test the temp both before and after the cat with a lazer thermometer. If the temp behind the cat is way lower than in front its clogged, if my memory serves me correct. I haven't worked in a muffler shop in like 4 years, but I think thats the 2 methods we used. I guess you could also take it off and try to look or blow through it as well
odds1
Post by odds1 »
I can smell the rtten eggs smell all the time.
Then probably the cat is partly clogged i guess.
Is there anything I can do to fix this or do I have to buy a new one?
Odds
Odds, Norway
Red `93 GS, Stock
neutral
Post by neutral »
Replacement is the only option once the internal element gets clogged. Of course, you could always just core it out, reinstall and have a "pretend cat." :wink:
fieval79
Post by fieval79 »
lol, pretend cat!!!
That's what I'd do........ :roll:
MarkMoore
Post by MarkMoore »
sure, that's a great solution until inspection rolls around... then be prepared to fail emissions :x
neutral
Post by neutral »
ya, I was just kidding on that suggestion and where I live, my state MVA/DMV slaps on a MONSTER fine if they discover you messed around with the cat like that. Rumor has it that they even force you to hang your gonads over an open file drawer while the DMV person slams the drawer shut. YEOW! That has just GOTTA hurt! :shock:
Grants
BANNED Member
Post by Grants »
Did you mean "MEOW! Thats gotta hurt"? :D
neutral
Post by neutral »
LOL :lol:
bmwm3guy
Post by bmwm3guy »
common meow, enough with the shinannigans
