woah..those look easier and smaller then the civic ones...where are tey from? also ..is that 2 projectors i see and 1 turn signal.? they look nice.
-hec
-hec
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
They are £100 each but should be worth it> and yeah they do require some bodywork.
I was gonna have some other lights moulded into my car but decided to use these. HOWEVER i'm still waiting for my kit the two suppliers aren't really helping me cos i'm in the UK. It really sucks next time i'll just come out there and bring back the stuff myself!
If you gonna use these in North America, you will also need a set of different projectors in there with a flare to the right, not left (they drive on a different side of the road).
