How do I remove them?
How do I remove stickers off the side of my MX-3
I just recently bought a MX-3 and I don't like the stickers on the side.
- Custommx3
- Site Administrator
Re: How do I remove stickers off the side of my MX-3
well, if its the body decals, a heat gun will work.
lakersfan1
First obviously, remove the sticker.
Then ......... Bug and Tar Remover might work. Otherwise, you can try one of the various less toxic adhesive removers out there like 'Oops'. Something like 'Goof Off' would be a last resort since it's pretty strong stuff and might damamge your clear coat.
- Custommx3
use the heatgun to heat the decal, u can use bumper sticker remover or the others listed to remove the left over adhesive.
Eucalyptus oil is the best stuff to remove stickers.
- mitmaks
heat gun, eraser wheel, basically big eraser wheel that u stick on drill and it just rubs off decals
Great tips guys, appreciated.
Mastirmynd
rubbing alcahol works too, but probably not the best way to remove BIG stickers. I used it to take off the alarm stickers.
Build A Man A Fire, He Will Be Warm For A Night. Set A Man On Fire, He Will Be Warm For The Rest Of His Life.
<img src="http://www.bareend.com/mazdaspeed.gif" alt=" - " />
methyl hydrate - will not wreck your paint/clear coat, and will get rid of every last stickt crumb with not much effort.
Where do you buy methyl hydrate?
