FS: B6T in Calgary + mods
Hey all I got a B6T powered 5spd 323 sitting here it runs/drives perfect except the car itself was rear ended so it's for parts only. I also have a larger vj11 turbo from a mx-6 that you can put on or do a hybrid with the stock vj14 turbo. I also have a mx-6 intercooler that can be used in your motor swap. I'll let it all go for $1100 CAD firm. With a chipped ECU and bigger exhaust you can run 16-20 psi all day long.
