Recently me engine has suddenly just started cutting out for no reason that I can see. Even at highway speeds. I can start it up, drive it for a minute and then suddenly RRRr........ It just dies. If I let it sit for a minute or so, I can usually start it back up again, but it dies soon again after. At first I thought it was my PCV valve because it had a crack in it but I replaced that and the same problem still exists. Most people would suggest the Distributer but I replaced that 5 months ago. And besides, usually the car stumbles and hessitates a bit when that starts to fail. I ran a diagnostics and the car coughed up the following error codes.
02 'NE2' crankshaft position sensor
03 'G' camshaft position sensor
16 Exhaust gas recirculation (EGR) system
17 LHO2S inversion error
24 RHO2S inversion error
I can't say that I've ever seen this combination of errors before. Does anyone know what this means.
Oh, and by the way... it's a 1993 GS.
Now the last I tried was resetting the computer by disconnecting the battery for 1 min. After that I reconnected it and restarted the car. It ran again just fine for about a minute and then just cut out. I re-checked the Diagnostics for any error codes but there were none. Usually I'm pretty good with these engines but this has got me confused.
<small>[ January 30, 2004, 11:53 PM: Message edited by: WyldSide ]</small>
